Pucking Froblem solved with car being lean!
U
UB2 SLOW
:hb :hb :hb :hb :hb :hb :bash :bash :bash :duh :duh :duh :mad :mad :mad
All right I finally found the pucking froblem with the car running lean. I did not tighten the bottom left bolt on the TB the last time I took it off. I had it screwed in until it was tight using my hand and I guess I just forgot to finish. One problem down.
have you re-tuned the the fuel pressure now? the car should be much easier to tune now that the MAF is sending correct information!
So what you are trying to say is you really, honestly SCREWED up (or shall I say you just did not screw enough) to the point you were really sucking! (extra air in, that is).
Hey, get your mind out of the gutter! That is a legitimate technical term in this circumstance!
Yea I reset the fuel pressure back to 47 for now. I am going to go to the Dyno this weekend. I will tune it then.
69myway, I guess I am the typical man! I just cant screw enough!:D
But in this case...
I think you ended the screwing prematurely!
h
:L:L:L:L:L
Just like a Marine....it may take a while but we always get he job done...
I was feeling prankish!
Sorry if I offended anyone!
Heidi
