W
waynepeele
1976 has new calipers,pads, rotors turned,new fluid, new flexible line and still pulls left when braking.any hints.
thanks80convertible said:Verify that the pistons are actually working. My vette would pull way left when braking. I finally got in there to inspect and found that the pistons were not functioning properly causing the brake pad not to fully contact the rotor. I could actually see the improper wear pattern on the pad. In my case the parts were not new.
I hope that you find your problem, but I have found that for problems such as this, that it is necessary to go back and look at everything associated with the system and assure they are working as expected before chasing a bunch of other things such as alignment, ball joints, tie-rod ends, etc.
