captainrags
Can anybody help. Im looking for a Vapor Canister Purge Valve the electric one and all I seem to find are the smaller units that are not electric.
1996 LT4 6 speed
Ray
:W
1996 LT4 6 speed
Ray
:W
Can you be a bit more specific about your needs?
Do you need the canister purge solenoid or the canister purge valve. Also, from your sigline, we'll assume this is for a 96 with the LT4 (VIN 5) engine, but if it's not, post the application.
I need the Vapor Canister Purge Valve NOT the solenoid. Yes its a LT4 Vin) 5 1996
apreciate any help
Thank you
Ray
Did you confirm presence of vacuum at the cannister when you jumped the purge solenoid? If no one can post the 12V schematic, you can still bypass the switched purge port, to see if vacuum carries THROUGH the vac line AT/TO the EVAP cannister.
There has been some terminoligy issues the two parts 1. the "vapor canister purge valve soleniod" the square unit and 2. the "Vapor canister purge valve"
I purchased both however the solenoid seem ok but the valve dident have electrical connections so hopfully this new purchase im waiting for will be the correct one. As part numbers have changed and all are very simular numbers verry confusing.
With the testing i removed the hose from fuel tank to find suction! was I wrong?
With the testing - the solenoid bypassed either 1) by jumping the 12V switch, or 2) bypassing the vacuum port, then NO, you were not wrong, and YES, you should have had vacuum at the tank, under either of those 2 conditions.
But which did you do?
Did you jump the solenoid - to complete the electrical circuit, and 'activate' vacuum?
Or did you disconnect the vacuum tubes at the solenoid, and connect them, which would have also supplied vacuum?
No I removed the line coming from the rear of the car and felt the suctions on the intake opening of the purge valve, for the two tests
I did not jump the solenoid just ran the eng with wires pluged in and out only on the Valve, as the tank or line coming from the rear goes into the valve and thats what i refer to as the valve intake port this is of course before the solenoid. therfore it apears to me that the valve should be open with its wires pluged in and closed when the wires are out but it was not the case there was suction all the time but less when the wires were out. I will put the old solinoid back on tomorrow and with the existing valve test it again. If I can get it started.
I know it an old one but, just replaced the top radiator suport and now she just wont start cranks good and then smell of alot of fuel dident touch distribitor check and double checked all my work this has never hapened before any help would be apreciated, 1996 LT4.
Ray
:confused;help
I think maybe stick at this thread, and solve this electrical problem (if I understand what's going on as you describe). The electrical problem MIGHT be what's holding you from starting.
So maybe lets make sure what's going on in the purge solenoid - if the problem is electrical THERE, and it's continuous, and not intermittent, it is easy to fix.
DO you have FSM? Do you have multimeter?
You need to find then the duty cycle description for EVAP purge, and then find the test description/flow chart (will be in a different section from the description, I believe).
Your description sounded like it is always in purge mode, with vac supply at the tank. If so, the question will be 'Which parameter is triggering the 12V supply TO the solenoid'? Something like faulty speed signal, rpm signal, etc. Look at each 'condition for purge'.
This wont start is driving me crazy check and check about all I can do with my limited knoledge.
I have service eng soon light but no codes except second air error I will replace the small tubes tomorrow in that area.
this started after replacing top radiator suport but have been having trouble with purging manual hasent helped and I get confused with all the eng control stuff.
Would appreciate any help that I can use
;help
Hi, the canister purge valve is electric, prt#212-358, go to ebay, costs about 10.00Can anybody help. Im looking for a Vapor Canister Purge Valve the electric one and all I seem to find are the smaller units that are not electric.
1996 LT4 6 speed
Ray
:W
