O
omega1940
I'm in the process of rebulding my 88. I'm into this rebuld big time and have a few last minute questios from you experts. So far here's what's going into the engine. (I already had a 52 mm Throttle Body, Flowmasters, K&N, etc.)
Scat 383 crankshaft, pistons, rods, rings. Clevite 77 bearings
Accell SuperRam Intake
Accell long-tube runners, polished and ported
Ported plenum
Bosch 24lb. injectors
Crane "Gold" racing rollers
ZZ11 camshaft (duration @ .050 214-227, lift 480-518 Lobe 112)
MSD 6AL ignition
Performance Products HEI Coil
Double Roller timing chain
New Harmonic balancer
New flywheel
Centerforce II Dual Friction Clutch disk, Pres. Plate
Hooker headers-powder coated (special bolts, retainers)
8.5 mm. spark plug wires
Ported heads, new valves, etc
I was cleaning out the engine bay in prep. for the rebuild Monday, and saw the old pushrods. These things probably have 144,000 miles on them. Also the oil pump looks like it is original.
My question(s):
1. Should I get new pushrods and if so, what kind?
2. Should I get a new oil pump? I don't know how much oil pressure this new system will need. Is a new GM stock oil pump okay? (Actually I've already decided to replace it, just want to know if a stock oil pump will be okay.
3. What kinds of plugs? I've used Bosch +4's for 20,000 miles and they seem fine.
Thanks, Mike
PS: Jeff is reprogramming my PROM chip to take care of these mods.
Ported plenum
MSD 6AL ignition
New flywheel
My question(s):
Thanks, Mike
