M
magoo
Hi Jeff
Your fan speed won't have anything to do with your compressor engaging. It sounds like your system could be so low on freon that there is not enough pressure to engage the clutch. Do you have the low pressure switch Bill showed in his pic? I don't think you do. Has this system worked recently? If so and it blew a large leak, you should see oil at the place where the leak opened up. If it's empty, it may make sense to convert it to 134 at this time. I wish we lived closer I still have some r-12. The fuses I have here have those same letters on them and I don't remember what they stand for. I will research some old Chilton manuals and see what I can find. Do you have guages to charge this system yourself? I will try to talk you through it if you want.
Mike
Mike
