Ok, I need some advice on tunning my carb on my 80. I'll run ya thru what's going on... replaced the heads ( same as original, stage 1 port job) cam, Energizer 266H, Aluminum L82 intake, (which was on the car) new duals, not cats. Put it all back together, ran fine, as a matter of fact ran great! Did the break in, changed the oil, and ran another 100 miles or so, and decided to start tuning the carb, which I removed the caps from the adjusters while I had everything apart, made my little tool to turn the screws, hooked up the vacuum guage and started to play. I searched for the highest vacuum, and the idle smoothed right out, and the car really purred. I thought I really had somethng, then I took the car for a drive and the low end torque and response was gone, it became a down right pig. Came home and rechecked the timming, it was fine, what happened?
Ron
Ron
