bat1954
New member
Just to let every know about my install of these shocks. Original Bilstein's where pretty worn out. The TS 511&TS512 I picked are stated they are OEM fit. Not at all. The rear shocks are a smaller thickness at the bottom mounting eye than the originals. To make them fit and keep the closest geometry to originals I used 9/16 washers drilled out to 39/64 to go onto the mounting stud to provide a shoulder for the inboard and outboard side sleeve you install thru the rubber bushing to seat and crush the rubber. I used one on the inside and two on the outside. On the front shocks the supplied mounting bolts are to large of an OD to go thru the mounting holes and are to short also. Used the factory mounting bolts and placed 5/16 washers on top of T Bar lower mounting. QA1 has a mounting stud kit that I later bought to see if that would make a better mounting system for the rear shocks. I have not put them on and probably will not as it will angle the shock to much for my liking. Anyway I am not suggesting to anyone on how to install or influence a purchase decision in any manner. Just relaying my thoughts and my install. I did call QA1 and the person I talked to was of no help as to why they were not a direct fit. Maybe I just got the wrong person on Good Friday. Currently I am adjusting for ride control and am at nine clicks from lowest setting. Only time will tell if I should have put Bilstien's back on.
Don
Don
