69 Driver
New member
When rebuilding the Quadrajet for my 69 350/350, carb #7029207 i neglected to notice which way the baffle in the secondary bores should be oriented. There is a small box-like structure on one side of the baffle in one bore. Does this orient to the front or rear of the carb? It will fit either way. Maybe someone has this kind of baffle and could look at it to see which way it orients...
Also, i think the date code is 0393. Does that mean it was probably a replacement unit built on the 39th day of 1973, even though the model number is correct for this engine? Any comments on that?
