68BigBlock
I have a 68 Big Block, 427/390 numbers matching car with Quadrajet carb.
;help Car is vapor locking on me during summer drives when I stop engine and attempt to restart. I run mixture of 100-octane racing fuel and 93-octane, non ethanol.
Car has the "smiley face" aluminum intake set up - I've made all the gaskets updates per LARS guidance back in the winter.
Seems heat is boiling the gas out of the carb -- let it sit for 25-30 minutes and it fires right up.
My questions:
1. I believe I need some type of phenolic gasket/heat insulator between intake and carb -- can anyone who's had this issue and corrected it with this solution please comment on what products you used and where sourced?
2. On the topic of the insulator, what is the maximum thickness I can use and not create a hood closure issue, or worse yet, jamming the air filter lid into the hood when punching it? Will the clearance allow for 1/2" insulator or is 1/4" sufficient? Again, anyone who's solved this problem would appreciate your comments and how you did so?
Many thanks in advance!
My questions:
