O Vette
I notice (perhaps many of you alread know) that Quaker State is selling a 10w30 oil with zinc added for the older cars. As I have read in a few places, this type of oil is good to use in C3's.
Almost all engine oil has some zinc in it. Does the manufacturer specify how much for this one?
Hib, I re-read your article and it does not answer my specific question or mention this new product at all.
Any oil that can be easily obtained at the local autoparts retailer. . .is 10w30 and has more than 1,300 ppm. . .will have my business right away!!
I'd like to know which product this is as well!!! Along with the amount of zinc. I've got an LT-1 mechanical flat tappet motor, and my buddies 396 is also mechanical flat tappet.
The only two oils that can easily be found (e.g. at local autozone, O'Riley, Walmart. . .etc. . .etc), which is streetable (e.g. not racing oil), not a desiel oil, reasonably priced, and has enough ZDDP in it to be (as far as we can tell) safe for a broken-in (e.g. you have already followed the recommeded break-in procedure using break-in oil) engine is:
- Royal Purple 10w30(SL rated oil) = 1,200 PPM
- Mobile 1 HIGH MILAGE 10w30 (SL rated oil) = 1,100 PPM
Note: there is a Mobile 1 product that has 1,400ppm that can easily be gotten at the local store. . .but the weight is too high for me. I think it was the 15w40 oil . ..but I don't remember if it was regular 15w40 or High Milage 15w40. Mobile publishes their ZDDP levels on a pdf (via goolge search) which you can find if your really interested in that oil. I do remember the back label saying that it was fortified with ZINC for racing applications.
My buddy runs Royal Puple, and I run Mobile 1 High Milage. . .and neither of us have experienced any failures or wear in out drive / valve train in over 3 years of use. I Put about 6,000 miles on my car a year. . .and it's been absolutly fine.
I know there are lots of specialty oils with 1,300 or more ppm (edelbrock. . .etc. . .etc. . ) but they cannot be (in my opinion) easly obtained when in a hurry.
If you are asking about the Quaker State product, I saw it at Walmart. Don't remember the actual name but, the zinc additive information was clearly listed on the lable. I didn't read the back lable to see if it mentions the amount of zinc.
More info...
Looks like 25% more zinc except the 10-40W that offers 50% more.
http://www.epc.shell.com/Docs/GPCDOC_X_cbe_24855_key_140007079157_201203220840.pdf
More than what?
Rightly or wrongly, 1200ppm is usually stated as the acceptable threshold. If you'd like a readily available product with that much zinc, just about every store including Wally World carries Rotella which contrary to internet myth and misunderstanding is NOT exclusively a 'diesel oil'. It carries the SM certification which is applicable to spark engines. SM is suitable for non-roller engines as found in our Corvettes.
Fire when ready, my flame suit is on and zipped up tight.![]()
More than what?
The vast majority of engines with flat tappet cams and overhead valves need enough ZDDP to have the phosphorous content at 800-1000 ppm and that includes stock engines with the most aggressive OE cams and some mild aftermarket performance cams. Engines with typical aftermarket "racing" cams and spring pressures might need 1200 ppm. The only engines which need more will be very unusual racing engines using very aggressive flat tappet cams and very high valve spring pressures. They might need 1400 ppm phos. With ZDDP, more is not best. Once there is enough phosphorous to prevent cam lobe wear more ZDDP will not extend durability. Once you go past 1700 ppm phosphorous, you risk chemical-driven wear of engine parts.
All engine oils of viscosity ratings of 10W30 or less which are rated API SL or less or are rated GF3 or less have a max of 1000 ppm phos and are good to use for any OE flat tappet cam.
Engine oils above 10W30 are exempt from max phosphorous limits.
In many cases the least expensive "high phosphorous" (1000-1200 ppm) engine oils are 15W40s or 10W30s intended for light truck diesels. Contrary to many persons' misconceptions, diesel engine oils make a lot of sense for high-performance street engines. They have more robust anti-corrosive additive packages. They are designed to lubricate engines subjected to severe duty cycles. They have higher levels of EP additives (ZDDP is an "EP additive") than do most gasoline engine oils. When I put petroleum-based engine oil in a high-performance engine I use either Chevron Delo 400LE 10W30 or Shell Rotella-T 10W30.
The idea that you must change your oil every 1000 miles is misguided, wasteful and harmful to the environment. The level of ZDDP remains consistent, regardless of the oil in question, for far longer than that.
Be careful of pour-in additives containing ZDDP. They exist to extract money from people not for any useful purpose which is not already addressed by existing engine oils. For one thing using them to spike GF4 oil with a higher ZDP content is expensive. Additionally, mixing the proper proportion of these additives is tricky. An oil modified to 2000 ppm phosphorous with an additive can damage your engine just like one with 600 ppm.
