- Thread starter
- #21
J
jmp
Well, I ordered the quartz conversion, so that, as they say, is that.
Thanks, everyone, for your help.
smurfvet said:The hands are supposedly "friction fit". My minute and hour hands loosened up quite easily. I put a small fork with narrow slots under each side of the hands and they pulled right off.
The second hand was another story. In repairing past clocks, I have broken the center shaft the second hand is fastened to. I read the same information- the hands should "pull right off". Maybe.
Try getting a thin but sturdy piece of metal with a thin slot in it- long enough you can get it under the whole second hand. Pull straight up equally on both sides at once, don't "wobble"- that will break the shaft for sure. I did it (broke it, that is) on another car. I have had good luck with the "puller" piece I just described, though.
Good luck....
