Question for Ken, Vig and C4C5Specialist
SPANISHVETTS
El puerto de Santa Maria Spain
before 60,63&82 now 90 383 Stroker & 91 ZR1-Sold
Yesterday I took the Vette out for the first time in 5 days. As soon as I got on the hi-way it started missing and the check engine soon light flashed a few times.
When I popped the hood I found the remains of a mouse attached to the #4 sparkplug wire. I removed the carbonized mouse and wrapped some plastic around the wire so I could get home. The car ran fine the 4 miles to the house.
This morning I pulled the codes and found, C41, H41, H72, and H 32.
I ordered a set of MSD wires which will be here on Thursday. I will not use the car until the new wires are on.
My question is could all of those codes have been set by the mouse chewing on the sparkplug wire while I was starting the car or did the critter chew up something else?
Man, you got me this morning Spanish. I thought I had something handy to decipher those codes but my books are with my car, and my car is far, far away... :eyerole
So, I haven't a clue as to the meaning of the codes, and whether or not they are related to your little friend, Topo Gigio, may he rest in peace. ;)
Good luck.
_ken :w
here is what i get, 41 (1985-1990) cylinder select error, check the connections at the ecm. check for an incorrectly installed, defective or incorrect prom/mem-cal. 72 gear selector switch, check the connections at the tcc solenoid and park neutral switch. replace the ecm or repair the transmission as needed. 32 exhaust gas recirculation circuit check the vacuum source and all vacuum lines. check the system esectrical connectiors at the ecm and egr valve. replace the egr valve or ecm as necessary. hope it helps robert
