ok, i'm going thru a lot of work to make my motor look better.
cleaning up the aluminum intake, valve covers, and exhaust mainfolds.Also touching up the paint on the block.
When it's time for re-assembly i'm using FelPro gaskets (#1256 was recommended) for the intake.
The problem is that the intake gaskets are blue and the edges of them between the intake and the heads are somewhat exposed and I don't want the blue color to show.
I believe from the factory the valve covers were masked off and than that small valley along the edges of the intake were painted silver to hide the factory gaskets and match the color of the aluminun intake.
Is my best bet to re-assemble everything and follow the factory procedure of masking off the valve covers and just carefully spraying silver paint such as aluma Blast along the sides of the intake allowing the overspray to hit the intake and intake bolts also, or should I just spray the gaskets silver before installing them?
I prefer the idea of spray painting the gaskets PRIOR to installing them so I don't run the risk of any overspray on my new paintjob but not sure if that will affect the sealing of the gaskets to the intake causing leak problems.
i'm NOT going for NCRS points, just a nicer appearance of my motor
Any suggestions or advice is greatly appreciated as always!
![beer :beer :beer](/data/assets/smilies/beerchug.gif)
