C
chuckndonna67
I have a radio antenna that will not extend. I have the system diagnosis steps from the Electrical Diagnosis Manual for 1987. In order to perform these steps I have to be able get to and disconnect the connector from the Antenna Relay. The manual says its located on the LH side of cargo compartment, above rear of wheelhouse. Ok so the cargo comparment is fully carpeted and glued down. Shy of tearing up the carpet is there an access point I should be looking for? (p.s. I know my fuses are good as I have radio power and my courtesy lights operate, so that leaves an open wire problem, relay problem or antenna motor) Thanks in advance for help in this. CAB
