D
desertsled
Hello folks this is my 1st memo, any help will be app...
1. can I change the rear leaf spring in my garage with a floor jack and 2 stands? I dont want that thing bapping me in the head. How hard will the center bolts be to remove? The shop wants to charge me 2 hours labor 140.00
2. I have the 3 speed auto. Here in Nevada, the speed limit is 75 mph, so everyone goes 80-90. If I take it over 65 mph, my temp gauge edges up to 220. As soon as I take it off the highway, it goes down to 175-180. Is this due to the very high rpms ? (3,500-4,000 @70 mph) I have replaced all of the coolant with 40% dexcool and 60% h2o. Water pump is new with engine. I also have a new fan clutch (how does that thing work anyway?) The themostat is good cause it falls off right at 185. I even tried water wetter (waste of 6 bucks) Do I need overdrive? 2,135.00 dollars, How about changing to a 3:08 rear gear? 750.00 dollars. Im worried about the summer here in Vegas
105-110 degrees is not uncommon. Will that plastic secondary fan come on during hot operation?, or is that only for the AC?
3. I want to fix the A.C. soon. Some mechnics told me to stay away from 134-a. It wont work and it will over pressure the system. Is it even worth it considering problem #2? I Know the compressor is bad. Any tips on replacing the accumulater ? I can barly see it no less remove it.
Thats all for this installment of "the never ending tinker toy in my garage"
