- Thread starter
- #21
S
sac001
I'll see if I can find a picture of the tool I made. It's pretty simple though, two pieces of Angle iron, about 1 1/2" by 1 1/2" by 6" long with holes drilled in it for 1/2" threaded rod. Put one of the angles in the gap between the differential carrier and underside of the car, and the other end below the spring. Put the "C" clamp behind the angle (towards the center of the spring to keep the angle from sliding) then tighten the nuts on the threaded rod to compress the spring.
The reason I used this was the car was up on stands, and when I tried to jack either end of the spring, I wound up lifting the car before I could get tension off the bolts.
To fab these I spent about $20 at Home Depot for supplies and it took about an hour to cut & drill. Actually you're welcome to borrow them if you need to, just let me know.
The entire job is considerably easier than it sounds, but stick with what you're comfort level tells you.
Good luck either way.
Steve
Steve
