69MyWay
This subject comes up often for those that want to add special fog lamps, cooling fans, or electric fuel pumps to cars that did not have them before. I will take a few moments with some photos and the aid of my wonderful animal assistants (see photos) to describe a quick inexpensive, yet professional way to achieve the goal.
In this first pic, is an example of a relay assmebly with weather pack as can be found in virtually any G.M. car after 1985. I prefer the oval bodied relays as they serve dual purpose as normally open, and normally closed (more on that later). You can get the relay in virtually any auto parts store for about $7. These relays are used for fuel pumps, cooling fans, lights, and horns. The one in this photo was pulled from a 92 Pontiac Grand Am. FYI, you can get this exact one from a parts counter for the cooling fan on a 1990 Corvette. The junk yard one will come with the harness/weather pack which is what you are after for a clean neat install.
Please note that the gauge of the wire on the weather pack will usually indicate the purpose of the relay. Small gauge such as in this picture usually indicates a fuel pump relay, or small cooling fan. larger gauge almost always indicates cooling fan assembly. I suggest you match your junk yard slection with your purpose. You can get just the weather pack as well from your G.M. dealer as a harness repair kit. Be patient, I have learned that not all parts men were created equal, so stay engaged with the part location process, as many will just give up looking. Again, I would suggest sticking with a 1990 vette cooling fan relay weather pack harness repair kit for larger diameter wires on a generic purpose, if a bone yard is not available and you want new wires.
