Help! Radiator baffleide bracket mounting
wood8835th
Colorado
88 35th and 75 w/ big block
Radiator baffle side bracket mounting
Anyone have any pictures of how the radiator mounting brackets mount to the
shroud?
I understand the mounting of the center braces but could use a little
help on the side brackets.
Please advise
I'm confused......
what are you asking for?
the airfoil in the nose area? those mounts?
or the top shroud? inside the radiator shroud? or the lower shroud where it mounts to the frame/chassis? A FSM would have the detail for all of these.
OR
are you trying to remount/replace the airdam?
Part R below. Not sure where they gio in the the radiatior shroud.
R goes inside part C to the side and rear, I believe R is there as one end of the mount for thr airfoil thatsits across the open area,with its ends attached at the side of the box by a metal bracket---R that is IIRC....:thumb
