- Joined
- Apr 8, 2005
- Messages
- 274
- Location
- Charleston, SC
- Corvette
- 1981 Dark Blue Metallic, 2003 AE coupe
Just got a leak in the upper (fairly new) radiator hose and don't like the way it appears to have happened. Easy fix to replace the hose, but looks like it was caused by the alternator belt rubbing through it. Can someone explain what the proper clearance is for this hose and the fan on the front side and the belt on the rear side? I thought about braided protection for the hose, but that just leads to more belts. This happened following a wonderful cruise of about 200 miles on Saturday, combined backroads and interstate. A picture is worth a thousand words. I do have an issue from the previous owner who had the water pump replaced and therefore the belts are slightly misalligned. They are slightly farther forward than normal at the pump and angle back just a bit to the alternator. Any help would be appreciated.
Thanks,
Mike
Thanks,
Mike
