Ludigdrums
The upper port on the radiator that the upper hose connects to is loose, and of course I'm leaking from there. I originally thought it was a hose, but when I took the hose off, I reallized that piece was loose.
It almost seems as if it were made to come out, like there is a ring around the bottom. It's only attached at the very bottom. I was able to get it back in, but I can't see how that makes a tight enough seal.
What are my options?! Do I need a new radiator?!
Thanks as always!
- Jeremy
Thanks as always!
- Jeremy
