sincro
Active member
I just installed an after market AC/heater unit in my 65 coupe as part of my partial restoration. The engine is a small block with something a little over the stock 300 hp. It has a 4 speed transmission and 3.70 rear gears.
I am having problems with my cooling system running hot both with the AC on and with it off . I washed out my radiator (found a bunch of mud in it) until clear water came out, blew out the fins, installed all new hoses and 160 degree thermostat and washed out the engine block. I installed the two electric fans, that came with the kit, in front of the condenser as the instructions suggest and they run in the correct direction. What can / should I do to correct this problem? Should I pull the radiator and have it chemically cleaned? Is it possible for the water pump to be not pumping enough water (original pump but no leaks)? Should I put a six blade fan on the engine with more pitch? (Yes the fan cowl is in place) Could the condenser be blocking too much air from the radiator? I have not installed antifreeze / coolant since the overhaul.
The temperature goes up to 180 degrees and holds there for a while. It then starts creeping up and eventually reaches about 220 to 230. (while driving about 55 mph)
Suggestions to solve this dilemma will be appreciated.
