Radio/Horn/Cruise Don't Work?!?!
  • Thread starter Thread starter asby69
A
asby69
Hi all,
Just wanting some help if possible. My CD player/Horn/Cruise doesn't work, is there a fuse or relay that works all of them that may be bad?
Thanks in advance!!:cu
asby69
asby69 said:
Hi all,
asby69
I guess that I could've told you that the problem is on the '90 Vette.
asby69
Fuses.......
Yep, checked all fuses. They are good. From what I've read here on the forum, the CD player is probably shot and needing replaced. I'm still stumped over the cruise and horn not working. Is there relay's that work each of these? If so, where are they located on the vette? Thanks for your help in advance.
asby69
:pat
They are probably all separate issues. On the cruise look around the unit and make sure that you have no vacuum leaks. Also under the dash there is a brake switch and if it is out of adjustment it will not let the cruise engage. On the horn look for the relay placement in your owners manual.
