I have an Alpine radio in my 78. It has a power antenna. I tore the console apart to fix the reverse lockout. I got that fixed and got everything back together again. Now I have a radio problem. It is eating 3A fuses like M&Ms.
There is a red wire that comes from the power source to a 3A in-line fuse and on to the radio. Another wire comes from the back of the radio to a 3A in-line fuse and off to a unit under back of the emergency brake. From this unit come the wires that go to the antenna motor. So, the radio wires go into the top connector and the motor wires come out the bottom connector.
I have checked all the wires for bare spots. None found. I thought that maybe the neutral and reverse lights were getting caught on the shifter mechanism (it is an automatic). So I tore it all apart again and ran the wires under the shifter plate, out of the way. That probably needed to be done, but that wasn't it.
If I have a fuse in both places, when I turn on the radio, one of the 2 fuses immediately blows. I put a 10A fuse in the antenna unit, as a test. The antenna went about 3/4 of the way up before blowing the 3A to the radio. So, I know all the antenna stuff works, it is just drawing somewhere between 3 and 10 amps. Why? It never used to.
I have 2 ideas. One is that there is STILL a bare spot somewhere and I just haven't located it, or the other is that the unit between the antenna fuse and the antenna motor just happened to go bad at this inopportune time.
Is that unit a transformer or a relay? I have no idea. However, when I turn the radio off, it makes a popping sound. There is nothing in my 1978 Corvette Assembly Manual that even makes reference to a power antenna.
Each time I go into AutoZone, I cause a laugh and they head right for the fuses. How embarrasing. Help a guy out.
