toptechx6
I am a new member and this is my first time to use your form. So if I do something wrong please let know. I have a 1996 C4. I just had the oil changed about 2 weeks ago. Now the change oil light came on. Could you tell how to get it off. thanks
Oil Change light reset (short version) :L
Oil Change Light Shut-Off Procedure
1. Turn the key to the RUN position but don't start the engine.
2. Press the ENG MET button on the Trip Monitor. Within 5 seconds press the ENG MET button again.
3. Within 5 seconds of step 2, press and hold the GAUGES button on the Trip Monitor. The CHANGE OIL light will flash.
4. Hold the GAUGES button until the CHANGE OIL light stops flashing and goes out. This should take about 10 seconds. When the light goes out, the Engine Oil Life Monitor is reset. If it doesn't reset, turn the ignition to OFF and repeat
procedure.
