jjaymoore
I just got my '86 a few months back and am in the process of fixing everything that the PO either rigged up or didn't fix on the car (which is a lot!). Anyways, my rear brakes are dragging. I can shift into neutral at like ten mph and the car will come to a complete stop as if the brakes are applied. I tried bleeding the rear brakes and they will not bleed at all unless the car is running. I do not have an ABS light and the fronts are working fine. Has anyone experienced this in the past? I have never messed with ABS systems so any advice would be greatly appreciated.
