7
70 VETTE 454
hello again everyone, been a while, but been busy on my frame and suspension lately...
well I just started on removing the rear suspension on my 70 the other day, but I can't seem to remove my rear disks from the hub assy. :confused They have been on there for over 30 years, and don't look like they have ever been disassembled, maybe they are just really worn together. I was told they should just slide off like drums do, but they don't seem to want to work like that at all. I did everything short of banging on them,
cause I don't really want to mess up the rotor. Also, I just don't want to start taking off bolts, even though it is all coming off eventually, cause I think it is easier to take off with the independent control arm still attached to the frame. Any suggestions on how to remove them, or what have been any past experiences......
I have already removed my leaf, and half shafts, and all the emergency brake lines as well as calipers and every associated brake lines and all that is holding it in place is the strut rods, shock and rear control arm. ;help
the front ones came off the spindle with ease, but that's not the case with the rear....do they need to be persuaded.....
thanks again, and all help only makes for better knowledge to help out someone else.....in need....:cool
Dave
p.s.
pics of the entire process to follow when done with this part.
Dave
p.s.
