chuckhinva
After replacing everything rear-end related from the drive shaft back, I'm still getting a clicking noise when I drive. You can hear it best when slowing down. Applying the brakes doesn't make a difference. Sounds like a bad u-joint but they were replaced (twice).
I read somewhere that a worn yoke will cause the same kind of noise. Any suggestions on how to check yoke wear?
Any suggestions on other sources?
