Rear Hatch Rattle on Convertible
  • Thread starter Thread starter marct
M
marct
Anyone know a the best way to adjust the latch on the hatch for the convertible top behind the seats on an 93 Covertible?
The driver's side latch has a little play in it and rattles going down the road. I can't see any obvious adjustments and don't want to start digging into it until I know more.
Marc
;help
I'll answer my own question.
Three allen bolts secure the latch mechanisim. Loosen slightly and move up and down as needed. Easier than it looked at first glance.:bash
Loose Hatch on Convertable
Hey Topless, All I did was turn the spring mechanisim (located on the hatch) down a notch or two that makes contact with the latch mechanisim. There are one on each side and you can adjust with your fingers. I loosen them until the hatch would not lock and then back them up until the lock catches hold and then turn them another half turn so the hatch operates smoothley. I don't know how you got any adjustment out of the allen bolts, they are the one that holds the latch in place???.;shrug;):beer
Yes the three bolts hold the latching mechanisim in place. Once you losten those the latch mechanisim will slide up and down. I had found the adjusting screws that you mentioned, the problem was that the hatch on the driver's side was sticking up slightly. I wanted to get the hatch down on that side. Can't create any excess drag with parts sticking out after all! After moving the latch down slightly I adjusted the spring mechanisim to make things tight. :upthumbs
TR:lou
TR:lou
Touche' O Topless Wonder, I just commited a Stupid Male Syndrome trick:bash I should have checked it out , but just looking I thought they would have no adjustment.....tsk.tsk.tsk.:grinshot
:reddevilSN
:reddevilSN
That was my worry as well, After having a nasty experience with the rear doors on my Tahoe (Hinges welded or bonded to the door, No adjustments or replacement possible) I was afraid the Vette might be the same, thankfully not!:)
