D
Dave Z
In December 04, I had the rear main seal redone. Yesterday I noticed oil on top of the rear of the motor below the distributor. Next, I found what appears to be oil blowback underneth the car and a very small drip (it doesn't even leak to the ground...yet) between the trans and oil pan. I have put about 700 miles on the car since the work was done, and the oil is almost 1 qt. low already. All gaskets at the valve covers are tight, no leaks. No leak at the oil filter, and no leak at the oil pan itself. Oil pressure reads the right at the first notch after 0 (but it's always read low and always at that mark, at start up and after warmed up). Is the first notch on the gauge 20 or 30? Does this sound like a rear main seal leak?
