Rear main seal
jenkx
Michigan
Has anyone changed a rear main engine seal without removing the ENGINE?
My concern is re installing the oil pump shafts correctly.
Thank you
Sent from my SM-T550 using Tapatalk
Replacing Rear Main Seal
It's easy to do after the oil pump is removed. Just push the upper half out with a thin screwdriver and push the new upper seal half in. Put some non-hardening gasket sealer on the main bearing cap surface before installing it. The oil pump will easily go back in one of two ways and they're both correct. Torque the 7/16" retaining bolt to 60 ft/lbs and put the oil pan back on.
Thank you. That helps confirm my ideas.
Sent from my SM-G935T using Tapatalk
Smear oil onto the seal (both sides) before installing it and it'll slip in easily. Just make sure the lip of the seal is pointing foreword because I think it can be put in backwards.
