- Joined
- Jan 1, 2002
- Messages
- 7,246
- Location
- Washington, Michigan
- Corvette
- '67 Marina Blue Convertible
bbp said:Thanks for all the posts. Now im really confused. You say no small blocks had rear sway bars. I just bought 66 small block. I't has sway bar and 9 leaf spring. The spring need to be replaced, just wonder witch one to go with.I Don't want a real stiff ride, but don't want a soft mess. Will it make a big diffrence if a put in a big block for my spring selection?
Yup, no small-block C2 originally had a rear sway bar when it left St. Louis; at some point, all frames had the internal weld-nuts for the rear sway bar bushing brackets, so it could be added later (after drilling the holes in the top rear of the trailing arms for the link bracket anchor plate bolts).
If someone would start making a correct rate/ride height reproduction 9-leaf spring, they'd sell all they could make.
