B
b2758
Rear spring links need replacing. Any words of wisdom on how to relieve tension on spring to install new ones.
For safety, it's OK to jack the car up from the center but you want to have jack stands under the frame before you start work on the spring. Once you have the frame supported, you can start the spring removal process.Thats kinda what I had in mind. Jack the car up from the center and put another jack near end of spring to take pressure off ? I got a lot of respect for spring tension , thats why I asked. Thanks !![]()
