7
77corvsvette
As my wife backed out of the parking lot she noticed the noise of something metal falling on the ground. She looked out the window and saw a sheared off bolt laying there. I discovered it was one of the 4 bolts holding the rear spring in place, in the center. I also noticed that 2 other bolts were missing, leaving only one still attached. 3 are sheared off in the item above it. Is that the rear end cover of the differential that they are screwed into? If it is, is it easier to buy a new rear end cover than to try and remove the sheared off bolts?
thanks for your help in advance!!
