R
richardz
I have recently put on wider wheels/tyres (17x11 with 315 Goodyears) on my 95 convertible with soft FE1 suspension. The tyres hit the outer rear guard lip on corners and road dips. There is just under 3 inch vertical clearance with no one in the car. Do I 1) adjust the spring end bolt length for more vertical clearance 2) change to different shocks 3) change the rear spring 4) play with spring spacers or 5) some or all of the above. The service manual indicates 2 different springs (yellow/green code) is this right and if so which one is stiffer? It would make my dentist happier if this was fixed as I would not have to grit my teeth whenever I see a road dip coming - and there are plenty down here.
