Well, it's time to replace the rear wheel bearings again (this will be the third set in two years!), and I'm beginning to question if I'm doing something wrong when installing them! In all fairness, I take the car to the track several times a year, which I understand can have a somewhat detrimental affect on bearings!
I consider myself to be a fairly competent drive-way mechanic, and I have the FSM to work from. I searched for posts on replacing the bearings, and found a couple posts about making sure the splines are clean and using anti-seize compound on them. In the past I have just used high-temp disk-brake grease on the splines. Could this be an issue?
I could not find any posts, however, on the correct technique to hold the axle in place while tightening the spindle nut to 164 lb/ft. In past installs, I’ve had someone apply the brakes to hold the axle from turning while I torque the nut. Is there a better way to do this? I saw one post that suggested using anti-seize on the spindle nut, to get a more accurate torque reading. I have not done this in the past. Could it be that I'm not getting enough torque on the nut?
I certainly appreciate all the help I’ve gotten from you guys as I continue to learn about this great car!
Barry
Barry
