jad9943
Does anyone know how to troubleshoot a non working rear window defroster on a 1996 Collector Edition Coupe?:confused
Check the fuse first. A chevy dealership in Tyson Corner in VA worked on mine. Kinda long story but they said they fixed it. BS.jad9943 said:Does anyone know how to troubleshoot a non working rear window defroster on a 1996 Collector Edition Coupe?:confused
There is a defogger relay that controls the back window grid and the outside mirror grid. When you press the defogger button a ground signal is sent from the Heat and A/C controller head to the CCM. When this signal is received and ONLY if the engine running, the CCM energizes the defogger relay by grounding the other side of the relay coil. Voltage is the sent thru the circuit to the grids. The CCM will de-engerize the relay after 10 minutes.
