Peer81
Hello everybody,
Small problem with my engine.
First about the engine, all rebuild with new pistons and camshaft. Had a 30 to 40 minute break in period and has been driven for about 2 hours max.
Now when I start the engine it jumps to around 2200 rpm on the choke, no problem then and I can put it in drive and reverse with no problem. When the engine is hotter but still on the choke (around 5 minutes after startup) it still idles high but when I put it in drive or reverse the rpm drops fast and the engine stalls within 2 to 4 secondes. When I put it back in Park or Neutral the high idle takes over again and everything is fine. When I put the trans from park into drive or reverse and I push the throtlle there is also no problem. And for a forget I still have the original E4ME carb with ECM, tuned everything as good as I can get it. The exhaust is only the original short style headers with about 15" of exhaust tube after (still need to make a good exhaust system).
Does anybody know if this is a problem known to accure with new or just rebuild engines? If not, what is the problem?
Thanks,
Groeten Peter
Thanks,
Groeten Peter
