O
omega1940
I recently blew a head gasket on my 88 and decided to do complete rebuild. I went to a highly recommended shop and was told they had done many s/b Chevy rebuillds. I ordered parts from a local Corvette performance shop including a 383 roller assembly, ZZ11 cam, Crane rollers, etc. Also large-tube Accel runners, Accel SuperRam, Hooker headers. The heads were ported to .202. New GM hydrolic lifters, moly pushrods, 24 lb. Bosch injectors, etc., etc., etc.
Here's where the problem began. The guy who tore down the engine quit just as he got the engine apart. The new guy who reassembled the crank shaft (Clevite 77 bearings) pistons, etc. seemed to know exactly what he was doing, but when the engine was dropped back in I think he was immediately aware that he was over his head. He did not know where all the connectors went, vacuum tubes, etc.
The owner of the garage finally offered to have the car towed to the Corvette performance place in Tempe. They started looking at everything and it was a complete mess. Even the gaskets on the runners were upside down or on the wrong side. The shop carefully found all the connectors, replaced a few broken ones (I don't know if they were broken before or not). On Friday night at 11:30 p.m. we tried to fire it up. No luck. Turns out the fuel pump had died along the way. Saturday morning, new fuel pump, engine fired right up, but a coolant leak developed at the thermo housing. The gasket was replaced but it still leaked, so it must be a cracked housing. Tormorrow (Monday) they intend to put a new thermo housing on and fire it up again. When it was started yesterday (Sat. morning) it ran for a few minutes until we noticed the coolant leak. I thought the rollers sounded pretty noisy and so did the mechanic. A VERY experienced Corvette mechanic had adjusted the valves doing the zero lash, backing them off 1/4 turn or something like that.
Here's my question. Is it possible that the rollers are adjusted properly and during the engine rebuild (when the roller assembly was installed) something was done wrong. I was there when they put the crankshaft and rod/pistons in. The connecting rods sligthly hit the side of the block, which I was told is customary for a 383 modification. (bored out 30 thousandts) They ground a small space so the connecting rod would not hit the block and had 20 thousandts clearance. They manually turned the crank and it went around very smoothly.
Is it possible (anyting is possible, so I'm looking for "likely") that the lower assembly was done incorrectly somewhere along the way and the chatter in the rollers is due to a problem down below? I can't believe the guy who adjusted the rollers would not have done them perfectly. He had a remote starter hookup and would tap that to bring each roller to the right place then he adjusted each roller.
My big problem is that the new shop is chargine ME for all of the corrections to the initial shop. I gave the first shop $5k already and I'm living in horror at the thought that I'm going to have to have the new mechanic open up the entire engine again and correct a more serious problem.
Anyone got any ideas. Is it possible the rollers are not adjusted properly. The ZZll cam is listed as Duration @.050 214-227, 480 int. 518 exh. I was told this is a relatively mild cam.
When it was running it had a slight lope, and with the new headers and existing Flowmasters it sounded like it could thump a Viper.
Please give me some good news on this. I've got nearly $10,000 into this rebuild already!
Mike
Mike
