Recall Evidence
D
DkBG
Is there any way to tell if the steering column repair has been done on a car purchased used
Yoda
Administrator
Amarillo, TX
1981 UL5
DkBG ~ Welcome to the Corvette Action Center Community ~
Dk,
You should be able to have your local Chevrolet Dealer run the VIN and see if the recall was done. They can enter it into their computer system and find out for ya.
Welcome aboard, enjoy the ride ;)
Site Administrator
Staff member
Administrator
New Hampshire
1990 Corvette ZR-1
danl72
Chatsworth, CA
2008 C6 Coupe
Welcome to CACC. Also, when the dealer does a recall on a car they put a sticker under the hood to let people know that they recall was done. That is what the dealer did with my Vette for the recall. They put the sticker on the drivers side wheelwell. Check under the hood first. Good luck.
Tom Bryant
Administrator
Edgerton, Ohio, United States
1959 black 270hp (9/2/69) 1981 Beige L81(10/20/80)
Go down to Maxtons and ask my wife, Chris, in service to pull it up on the computer.
Just noticed that you are from Butler. I can't think of who you are though. I work there (Air Products) But other that visiting my Dad I don't hange around much.
Tom
D
DkBG
Thanks Tom , I'll do that . I have a Butler address but seldom have a reason to go there .
D
DkBG
Hey Tom I took my car in to Maxtons the other day . Your wife was very helpful . A really nice lady !
Tom Bryant
Administrator
:L She's nice to me sometimes too. As you probably saw for yourself, she is what makes that place work.
Tom
P.S. Is this right? My wife has actually met another CAC member face to face but I haven't.:confused
D
DkBG
I guess we'll have to do something about that one day soon !
D
David-F
One quick way to see if the campaign was odne on an auto is see if the column still locks if it does not and you do not have any warning messages then the campaign was done the 6spd you would have to see if there has been a change to the wiring at the BCM and a black relay installed above the BCM instead of the gray, you can't always go by stackers some fall of others never get put on a VSS would be a good check but you would have to stop by the dealer and have it looked up, but even then I have seen dealers charge GM but never do the campaign but this is not common but does happen. A auto get disabled but you could still hear the motor working, but the 6spd got a revised accuator and revised wiring and relay for the accuator enable relay.
David Fulcher
