meridian6
I have a 92 LT1 and have replaced three heavy duty batteries in last two years. Latest one is 3 month old. Garage kept.
Dead battery again. It is down to 11 volt (terminal to terminal).
Charger and cluster voltmeter show it charges between 14.2 and 15.2 volts, once I kick start and run it. Even after an hour trip, interior cluster meter never goes below 13.9 V?? Shut it down, won't start. But after attempting start I HAVE A RELAY OR SOMETHING CLICKING DIRECTLY BEHIND PASSENGER SIDE GLOVE BOX. Any ideas? Is it just a relay that is not getting enough amps or do you think the relay is bad and draining amps when car parked?? Even with ignition off and doors closed, it chatters for several minutes?? If I smack the front of glovebox, the vibration sometimes shuts it up! :CRASH NO!!, THERE IS NO ANIMAL IN THE GLOVEBOX!!
Anything you think of is appreciated. When the battery first comes off the charger, it is fine and everything runs fine, but still charges at 13.9v on interior guage.
