Viet Nam Vett
- Joined
- May 28, 2004
- Messages
- 2,410
- Location
- Egg Harbor Township NJ
- Corvette
- 65 BB 502 Cp /MSD ATOMIC EFI/ 2009-HUMMER H2
This thread was suggested by "67Heaven" from another thread . So I have Volunteered to Strart the ball rolling... Any one who would like to add or correct me ...Bring it on....
Yes...Relays are our friends. They do all the hard work carrying the heavey current load while letting us activate the load using very little current. As of now I am using 2 realys to operate my lights and 2 relays to operate the cooling fans on my radiator. Also..one relay to operate the electric fuel pump for my thirsty 502.
Heres a Link to Relay Activated headlights for your Midyear. The Site listed below was originally posted by John Z... Check out the listing under "Brighter HeadLights" http://www.madelectrical.com/electrical-tech.shtml
If the topic does not appear on the link look at the page top under Electrical Tech. You will find this very interesting...Thanks again John Z.
The Headlight Relays I have mounted on the Driver side and the Fan Relays on the Pasenger side. The fuel pump relay (No Pic) is mounted under the passenger side hood latch.
By doing the Headlight relay conversion you will see an increase in headlight brightness as well as less of a load on the insterment cluster as well as your headlight swithch.
I have to get out of here and head to work... Here are some pic's of my install
to date. I will also be adding a fan control switch and a fuel pump control swithch.. This will bring the total of relays to 8......
Driver Side Headlight Relays
Passenger Side Fan Relays
Fuse Block Assembly
Switches and Relays For Fan And Fuel Pump Control....Future Project
What Have you done with your relays......
Fuse Block Assembly
