Flaking Top
Hi, I have repaired my flaking top. It was fairly easy, but I did have the help from a friend at body shop, I took it in after hours, and he helped me. The proccess was quite simple, just use some wet sandpaper, about 1200 grit, to start with, sanding off all of the flaky stuff, once it seems to be removed, go over it again with 2000 grit. Then you will need to buff it out with a high speed buffer. It took several attempts to complete (all in the same evening) as spots around the edges kept showing up where the clear coat did not come off completely. It is also important to mask off the entire frame, as you can easily buff/sand the paint off the frame. Once the clear coat was off, and the top polished, it looks like brand new. I just wax it whenever I do my car, and it looks great. Hope this helps.
