Removal of front bumper
norwegianvette
Norway
1993 Aqua Convertible
Hello.
Can anyone give me a easy way to remove the front bumper on a 1993 so i can get to the lights?
Thanks,
Steve
I assume you mean the fog lights and turn indicators. You should be able to reach those from the front of the engine compartment with the hood open. Removing the front bumper seems like the hard way to access them.
Bumper
I can reach the bulbs but due to Norwegian law i have to put one more bulb in the indicator house (White light). Not alowed with yellow parking light over here.
Steve
Steve
Huh, I never knew that. Well, I've never removed the front bumper so I can't be much help. You should look in to getting a factory service manual.
I found one on Ebay.
Front Bumper
Hi again. I been in the garage most of the day and evening. I removed the clamp that secure the light and then used my dremel to make a 14 mm hole. This due to i went to the scrapyard and found a set of wires from a Fiat with connectors. Case closed but a big job it was. I now have white lights in the same house as the indicator is.
Steve
Very cool! :upthumbs
If you see a C4 with a front bumper that is not lined up correctly, chances are that someone took it off to replace the bulbs/fixtures and did not put it back on right!
It does take a lot of patience to do it right, but it can be done if you take your time.
SAVE THE :w
