removal of front side turn signal?
  • Thread starter Thread starter pauld
P
pauld
removal of front side tuen signal?
Hi,
Can someone tell me how to remove the front side turn indicator unit on the front fender. I have a workshop manual but it doesn't show the unit in the manual. it is the unit that illuminates a white light when using the turn signal.
Thanks.
you mean to change the light or the whole assembly?
Want to remove the whole assembly, has a bit of rust on the little fram of the unit and want to strip it down and re paint it and then put back in.
Just cant see what is holding it in and dont want to damage anything whilst trying to get it out.
two nuts on the inside of the fender one on each side of the wire for the bulb
Thanks Clar2001, will be removing them at the weeekend for a refurb of the units.
thanks again. Paul.
