T
trebor
Hi:
I bought a new o ring for the CPS. I can not get the bolt out that holds the CPS in place. A few questions for anyone who has done this:
1. Bolt size 8mm yes or no
2. Did you remove it from the top (sticking arm down passenger side next to power steering resevoir)?
or
3. Did you remove it with the car up on ramps from beneath the car?
4. If yes, did you have to remove crossmember?
5. Did you use an open end wrench or socket?
Any other tips greatly appreciated
trebor
or
trebor
__________________
1996 CE LT4, Z51, FE3
ad
