M
MyFlaVette
I'm thinking about getting a high performance intake for my '84 Coupe. Anyone have any experience with the Renegade?
You want real data or just SOTP resultsI'm thinking about getting a high performance intake for my '84 Coupe. Anyone have any experience with the Renegade?
Yes it will work and yes it will an improvement;I do want something that performs well
Exactlythere seemed to be a lot of bickering back and forth, but no real information on how the product performs.
Just looking to see if anyone is running the Renegade and if they are happy with it. I've read the old threads and there seemed to be a lot of bickering back and forth, but no real information on how the product performs. My 'Vette has a lot of mileage on it and I am trying to decide whether to rebuild the stock L83 with some improvements or just buy a crate motor. I'm not looking to race, but I do want something that performs well and looks and sounds great.
Sorry I can't contribute anything to the original question asked, but I can't wait to see the replies to this AGAIN!
Who hoo...
This is not a real simple decision. I 'improved' the L83 for a while, then swapped to a TPI system and a 406; NOT simple or cheap. The '84's computer is not the quickest/easiest to reprogram and is slow, while having limited tolerance to mods. I considered a dual-carb intake with the enlarged throttle bodies.I am trying to decide whether to rebuild the stock L83 with some improvements or just buy a crate motor. I'm not looking to race, but I do want something that performs well and looks and sounds great.
I have a renegade and it improved the performance of my crossfire. It is fairly easy to install, I recommend you buy a distributor wrench or similar to remove and install the distributor. You will have similar performance numbers as a TPI vette low 14's instead of the low 15's that a stock crossfire runs. It is worth it to purchase it, it is a bolt on install, I had to buy a set of TBI gaskets for mine, the renegade does not come with gaskets.
"nelson84"...can you post some engine or chassis dyno data from your comparion of the stock 82/84 intake manifold to the renegade?
As would I, having a project that I'd like to use my TBs on.I'd really like to see some objective testing of that product.
Thanks a million for your response. I will contact DCS on Monday to order. I understand that they are shipping backorders now. Don't know how long the delay will be but it's probably worth the wait. Also going with a restore/boring service on the TB's. Thanks for the heads up about the gaskets. Did you also replace the stock heads?
My engineering training and life experience tells me that amid the hype and lack of the objective evaluation, the intake, sadly, falls short of its promise.
