garyg
What is the secret to accessing the spring clip on the push rod under the dash. I dropped the hush panel and access to the push rod attachment to the clutch pedal is almost impossible. The clip must be removed before the clutch master cylinder push rod and the master cylinder can be removed. It seems to be virtually out of access under the dash.
