fhturner
- Joined
- Jun 23, 2003
- Messages
- 218
- Location
- Birmingham, AL
- Corvette
- '00 Torch Red Cpe, 6spd, '90 Red/Saddle ZR-1 #279
Hey Everybody--
I currently have the tires that came on my 2000 coupe when I got it at 60K miles (now just over 66K): non-EMT Goodyear Eagle F1s on the front and Falken FK-451s on the rear. The Eagles need replacing, but the Falkens still have a good bit of tread left. I'm leaning heavily toward the Goodyear Eagle F1 GS-D3s to replace the fronts. First off, any "objections" to this tire? It seems to be an excellent tire, and is fairly reasonably priced. Second, given that the Tire Rack has a $75 fuel debit card if you purchase all 4 Goodyear tires, should I:
1. Buy just the fronts and worry about the rears whenever they run out?
2. Buy all 4 and replace all 4 now to have a matching set?
3. Buy all 4 now to get the discount, but only install the fronts; install the rears when the Falkens wear out?
4. Forego the GS-D3s for now, and get some cheapo fronts (are the Falkens cheap?) so that both front and rear will wear out close to the same time?
5. None of the above? If #5, alternative suggestions?
Also, couple more Q's: Because I have not had a 4-wheel alignment since I purchased the car, should I do this upon installation of the new tires, or does it matter? And, does anyone know anything about or have experience with these Falkens?
Thanks,
Fred
Thanks,
Fred
