vette.vato
Is it difficult to change out the spark plugs in a 2004 corvette? Do I need to take it to a dealer or can I do it myself, I am not a do-it-yourselfer, but, I think it shouldnt be that hard to do, or am I wrong.
No,It's not rocket science,purdy easy actually!Is it difficult to change out the spark plugs in a 2004 corvette? Do I need to take it to a dealer or can I do it myself, I am not a do-it-yourselfer, but, I think it shouldnt be that hard to do, or am I wrong.
Heat sinks
Car forums repeat a few myths about greases. Forums usually claim dielectric grease thermally insulates connections. Forums also claim dielectric grease electrically insulates connections, such as in connectors and on battery posts. Neither is true.
Dielectric Grease vs Conductive Grease
Connectors
In radio frequency low power installations, in particular at low frequencies and/or when the connector has very little air gap, completely flooding the connector is perfectly acceptable. Flooding a connector is not acceptable at high power, because most greases will carburize when subjected to an arc. They will also change the dielectric constant, lowering the dielectric constant in the connector. This will create an impedance bump at very high frequencies, the problem's effect on the system being entirely dependent on the length of the bump in electrical degrees and the amount of the bump. (Not all things that show on a TDR are meaningful.)
In regular low voltage multiple-pin circuit connectors, such as automotive applications, flooding with a proper insulating grease of low-viscosity dielectric grease is perfectly acceptable unless a manufacturer recommends against it. The grease should have good stability and not contain metals in any form, and be specifically designed for use as a dielectric grease. This generally is a silicone dielectric grease, although some Teflon based greases are acceptable.
In single low-voltage terminals or connections, such as metal-to-metal joints, grounds, or battery posts, almost any pure grease of light viscosity will be acceptable. Caution should be used with greases containing metallic powders to be sure any metal is compatible with the embedded grease metal. Connection enhancement from embedded metal powder is very minor, if it exists at all, and there is increased risk of bad connections if the metal powder has any interaction with the base metals.
In single high voltage connections, such as spark plug boots or other high voltage connectors (x-ray, neon sign, or HV power lines), only pure dielectric silicone greases should be used. Generally a light coating or wipe is all that is required. Dielectric grease will actually increase voltage breakdown across insulators, especially in the presence of moisture. Never use or allow a metalized grease around HV connections.
The important physical characteristic is that any grease must have low enough viscosity to push out of the way at contact points, be water or liquid resistant, and be stable enough to remain in place as a protectant against moisture and air for a long time. It will not do any good to apply a grease that does not do required functions of excluding air and moisture, and lubricating the interface to prevent galling or fretting, for extended periods of time.
The most frequent Internet complaint is that dielectric grease insulates connections, making connections less conductive. The general basis for this claim is in the word "dielectric" used in the name. The word dielectric is assumed to mean the connection will have future problems because "dielectrics" are insulators. Generally, authors predict greases with powdered metal (in slang "conductive greases") will improve or maintain connection quality over time while dielectric greases will isolate connections because "that is what dielectrics do".
