Replacement block heater
ladams
Brampton, Ontario
1981 White
Ok, I've established that I have a leak in the frost plug hole around the block heater with the help of this forum. Now, does anyone know where I can get a new replacement or can you recommend a better fix (since I don't really need one).
Dump the heater and install a plain old soft (freeze) plug. :beer
The block heater is a dealer or aftermarket part, not from the factory. Best to ditch it as mentioned above. If you want a replacement, Canadian Tire has them in stock (what a surprise) :beer
